arcpy.CreateMapTilePackage_management
2391
07-06-2016 03:47 PM
ChetEgbert1
This command requires an .mxd as input map.  I need to be able to use it in ArcGIS Pro and send it a map from the Contents panel.  How can I kick off package creation in ArcGIS Pro?
DanPatterson_Retired
this link is for the Pro 1.3 help... which I am not sure if it is available in previous versions if you couldn't find it
Create Map Tile Package—Data Management toolbox | ArcGIS for Desktop
