ArcPro 2.5 Package Mobile Map Broken?
996
03-25-2020 07:48 AM
RichardHughes2
Helloo,
I've got an ArcPro Project that has seen a few updates to Pro.  We have a workflow for packaging maps into MMPKS and uploading to AGOL.  With ArcPro 2.5 the Package Mobile Map GP Tool started giving an error that the 'table was not found'.
I've removed each layer from the map but the error still exists.  I've also tried both creating the package locally and uploading to AGOL.  Same result on both.
No errors or warnings appear during the Analysis step.  This is what the log looks like.
Is this a bug?
RichardHughes2
Update - This morning I am attempted to create a MMPK using the GP Tool rather than the Share Toolbar and it worked.  I did have issues with being able to access layers from SQL Server, so after exporting them to a FGDB it worked.  Those sde layers use to work in ArcPro 2.4 so something has changed, not sure what though.  The SQL Server version is SQL Server 2016 SP2 GDR (13.0.5101.9).
Are there any known issues with ArcPro 2.5 and SQL Server 2016 SP2?
