ArcPro 2.5 Explorer tool will not let us adjust columns or select fields?
2137
6
02-11-2020 02:38 PM
JackieRivera
DanPatterson_Retired
You don't want to open the table?
PamelaBerry
No, sometimes it is easier to have the Identify or Explore parcel information pane open and docked on the map. In my instance, I want to have the parcel use description field selected from the appraisal district data so when I go to a new parcel to update the building use in a different feature class, I can just click on the parcel and glance at it to see how it is catagorized from them. This could be done through the attibute table, however our workflow has been through the Explore tool and now it does not function the same. Just wondering if this can be restored to the previous functionality.
If it doesn't function the same, you can always post on ArcGIS Ideas‌ to see if there are other people that share that need
PamelaBerry
Okay, thank you.
Guess I will do the advertising for you
https://community.esri.com/ideas/18004
PamelaBerry
Thank you!
