ArcMap models in ArcGIS Pro
1525
03-17-2023 07:58 AM
SLouq
by MVP Alum
I have some geoprocessing models I created in ArcMap, mainly because I understand VB syntax better than Python. However, I also would like to make these models work in ArcGIS Pro also. So I added the same toolbox I created in ArcMap to my ArcGIS Pro project and am now seeing two copies of each model which I created in ArcMap. The models work as intended in ArcMap so I don't want to mess that up. Since I have copies of each model when looking at them in my ArcGIS Pro project, would I be able to edit one of the copies without affecting the other so it still works in my ArcMap document?
DanPatterson
MVP Esteemed Contributor
You should read this
Migrate ModelBuilder to ArcGIS Pro—ArcGIS Pro | Documentation
and making a copy of your arcmap model and using it within Pro would be prudent to say the least.
There link indicates where Pro models can or cannot be used and whether they can be used in different versions with the Pro versions.
... sort of retired...
DanPatterson
