ArcGIS randomly selecting other features when editing
631
08-25-2022 08:02 AM
Nachytsm
Good morning!
I've been having an occasional issue with ArcGIS Pro, usually when I'm going through and editing feature attributes. I'm still not sure exactly what is causing it, but it might be autosaves?
When I edit a field in an feature and hit enter, sometimes my selection will change to a totally different entry in the feature class- so for example if I edit Stream A's Source field, hit enter, and then go to change the name of Stream A, after I hit enter I have stream F selected now.
I've also observed things in my drawing order being re/deactivated when this happens.
Assuming this is just autosave causing a hiccup is there a way to prevent it from doing that, without just turning off autosave? I try to save regularly anyways, but crashes always seem to happen when I haven't saved in an hour or so, naturally.
