ArcGIS Python Package Manager won't upgrade
1400
05-30-2025 06:19 AM
JoabelBarbieri
This never worked for me.
When I update ArcGIS PRO to a more recent version. All my python scripts stop working.
Then I try Package Manager>Upgrade an existing environment and it ALWAYS fails for me. I have to copy all python files MANUALLY from the default  C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\ to my ArcPy old environment's folder like C:\ArcPY
Why?
(Esri, any plans to replace the hateful conda ems?)
DanPatterson
MVP Esteemed Contributor
and you are following this?
Upgrade an environment—ArcGIS Pro | Documentation
what packages are you trying to install or upgrade that aren't in the arcgispro-py3 environment?
On a side note.  I never "upgrade" since I have found it far cleaner and faster to remove all vestiges of Pro (registry, folders etc etc) and install the newer version from scratch.  Then clone or create a separate conda environment after
... sort of retired...
JoabelBarbieri
Thanks for the link. I didn't know.
But anyway, having to manually reinstall all the dozens of packages I have added to my env each time sucks. Should be simpler.
