ArcGIS Pro - Utility Network
2723
05-23-2018 02:49 AM
rajeshkumarg1
Unable to share as web layers in ArcGIS Pro. The Utility Network extension is not licenced on the ArcGIS Server.
Suggest how to enable the extensions.
DanPatterson_Retired
The error number 00147: The <value> is not licenced on ArcGIS Server is referenced in the help file with solutions.
Whether it applies to that particular extension, you will have to confirm
AbhijeetKulkarni
You need to have Utility Network extension added on ArcGIS Server 10.6 for sharing as web layers.
rajeshkumarg1
But in my ArcGIS Server 10.6 extension of Utility Network is not available. In this case what can I do on this.
AbhijeetKulkarni
You need to reach your local ESRI vendor contact to get this additional extension. This extension need to be purchased separately.
rajeshkumarg1
Thanks for help. I will contact once with ESRI.
