ArcGIS Pro - set vertical exaggeration for the entire project
1198
06-22-2023 10:08 PM
EdK
Hi
Please let me know if there's away in ArcGIS Pro to set the vertical exaggeration to whole project.
This vertical exaggeration is mainly for viewing and interpreting purpose of Ortho mosaic drone images.
Thanks.
DanPatterson
MVP Esteemed Contributor
There is no default setting.
To examine what is available at the project level, go to the Project Tab, then select Options.  From there you can see what is available for various project level options like Display or Raster etcetera
... sort of retired...
Andrew--Johnson
Dan is correct there is no project or map level setting as this is a per layer setting. You can find this setting on the Elevation page of layer properties for operational layers. For the elevation surface you can adjust this setting on the Elevation Surface Layer tab https://pro.arcgis.com/en/pro-app/latest/help/mapping/layer-properties/elevation-surface-layers.htm#...
thanks,
Andrew
