I am running ArcGIS Pro 3.1 and have a working Python notebook that bulk downloads images from a Survey 123 feature layer hosted in an Enterprise Portal. The Survey includes repeats and I want the bulk download to include images associated with these repeats. I have tried everything:
For more context, the feature layer is named WHEG_Old_Field, the related table is displayed as oldfield_repeat_f1:notebook_table_name.JPG
When I look at the table added from S123 I see it named as:notebook_table_name_s123.JPG
I have almost had success with the following, but I'm still getting an error and the output name doesn't make sense to me or where the extra characters are coming from.
# Define Download Attachments From Related Table
def download_attachments_from_related_table(related_table_name, global_id, local_directory):
rel_attach_table = f"{related_table_name}__ATTACH"
rel_pic_fields = ["ATTACHMENTID", "GLOBALID", "ATT_NAME", "DATA"]
with arcpy.da.SearchCursor(rel_attach_table, rel_pic_fields, f"GLOBALID = '{global_id}'") as cursor:
for row in cursor:
pic_path = os.path.join(local_directory, f"{str(row[0])} {str(row[2])}")
pic_blob = row[3]
open(pic_path, 'wb').write(pic_blob.tobytes())
if exportCSV:
if not global_id in picDict:
picDict[global_id] = [pic_path]
else:
picDict[global_id].append(pic_path)
# Get Related Tables From Selected Feature Layer
def get_related_tables(feature_layer):
related_tables = []
for relClass in arcpy.Describe(feature_layer).relationshipClassNames:
print(f"Found relationship class: {relClass}") # Print for debugging
try:
relClassObj = arcpy.Describe(relClass)
if relClassObj.isAttachmentRelationship:
continue # Skip attachment relationships
if feature_layer in [relClassObj.originClassNames, relClassObj.destinationClassNames]:
related_table = relClassObj.originClassNames if feature_layer != relClassObj.originClassNames else relClassObj.destinationClassNames
related_tables.extend(related_table)
except Exception as e:
print(f"Error describing {relClass}: {e}")
return related_tables
This is the output from my debugging, it make no sense. It found a relationship class but it doesn't exist?!
I can post the whole code if that will help debug, but I'm mostly curious if anyone has any success downloaded image from a primary feature layer AND from all related tables? Any suggestions or examples to share? I have looked extensively and haven't had any luck.
Thanks in advance!
