ArcGIS Pro : Polygon fill (hatching) orientation doesn't match the legend
3401
04-24-2018 02:09 AM
Environnement_1Lausanne
Hello,
We're building a map on ArcGIS Online and are running into one issue. We have hatched polygons in our map and the hateched of the map don't match the hatches of the legend. This is probably linked to the rotation of the date frame.
Don you have any solutioon to make sure that the hatches have the same orientation in the map and in the legend ?
Thanks a lot,
DanPatterson_Retired
Fill symbol layers...
cryptically says that you can only change the line width and color, but then...
You define the arrangement of the hatch lines using the properties in the Pattern group. Define the angle of the lines by choosing from the Angle pull-down menu or typing a custom value. The Separation property defines the distance between the line symbols. Adjust the Offset property only if it is necessary to customize where the drawing of the line symbols originates from relative to the polygon boundaries.
