ArcGIS Pro/Model Builder problem
666
01-29-2026 11:48 AM
GaryMorris
I am building a model that joins to feature classes and then calculates a field in one based off of a field in the other.  I am getting them to successfully join but then the model fails while it is running the "Calculate Field" tool:
ERROR 002717: Invalid Arcade expression, Arcade error: Field not found Permits_Agg_2025_Test, Script line: 1
The fields are not populating for me to select them, so I manually entered the full field name using both feature classes but am still getting the error.
I am using ArcGIS Pro 3.6.1
Any help is greatly appreciated.
DavidSolari
MVP Regular Contributor
This might be an Arcade limitation, if you use the Python calculation mode does that work?
GaryMorris
No, it tells me it is an invalid field as well.
Robert_LeClair
Esri Esteemed Contributor
Typically the ERROR2717: Invalid Arcade expression means an invalid syntax error as referenced here - 002717: Invalid Arcade expression—ArcGIS Pro | Documentation - can you provide the Arcade expression you're using?
GaryMorris
It is just making one filed match another field so it is $feature.fieldname.  Since it is a joined table I have also tried $feature.inputtable.jointable.fieldname
