ArcGIS Pro Model Builder help with creating points
202
10
a week ago
KevinColtart
I am trying to build a model in ArcGIS Pro Model Builder that uses user-entered longitude and latitude values to create Start and End point features, validate that both points fall within another polygon feature already in the project, create a new selection of the polygons that those points sit within, expand that selection to connect the two points (the polygon is a linear feature made up of sections) and then generate a new record using the selected geometry in another feature.
I am completely new to Model Builder but see that creating a custom tool could help me and my department save a lot of time.
Starting from the beginning and the variable that I need to start with. From research online, I began with variable parameters set to double format. But everything I try to do to create points from them is not working. Could somebody help me please.
BobBooth1
Great! Glad you got it working. Good luck with the rest of the tool!
