ArcGIS Pro Layout Snapping not working
10919
17
11-09-2017 12:54 PM
GregFiske
It appears that snapping in an ArcPro Layout is still not working.  Can someone say when this will be fixed?
I've read the docs and I think I'm doing it correctly, but I keep getting the same response.  I'm using version 2.0.1.8933
Thanks.
Robert_LeClair
Esri Esteemed Contributor
In your Layout View to the right of the scale box is a Snapping button to click.  If it turns blue, you've enabled snapping.  From there, you can choose to snap to guides and/or elements.  I'm using ArcGIS Pro BETA 2.1 for testing.
GregFiske
Thanks for the reply Rob.  The snapping button appears to have no effect (whether on or off)...
Greg
Robert_LeClair
If you hover your mouse over the Layout Snapping, it "expands" a small UI.  Inside you'll see Guide Snapping and Element Snapping.  Click either or both to enable those two snap agents in the Layout.  I'm working with Pro 2.0.1 so do not know if 2.1 Pro will have additional snap agents.
GregFiske
Hi Rob - thanks again.  See attached animated gif.  Am I missing a step?
GregFiske
Also, I'm currently using ArcPro version 2.0.1
Robert_LeClair
I see what's happening - when you hover over the Layout Snapping area, you're just turning it on/off but setting the snap agent.  Below Snapping is off/Snapping is on, click one or both snap agents so they too are blue.
JeanetteHarlow1
I, too, am having this problem.  I have done all that you suggested, as well as the suggestions to restart the program.  The snap feature will still not work for me, even though the snap icon at the bottom left says that it is "on".  I'm using 2.3.1.
AdrianWelsh
MVP Honored Contributor
Jeanette,
Have you tried messing with the snapping settings in the snapping area?
Have you gotten other layers to snap? What kind of layer are you trying to get to snap (point, line, polygon, etc.)?
JeanetteHarlow1
Hi Adrian,  I have tried adjusting the snap settings.  It seems to be intermittent.
