Arcgis Pro Label Expression
1539
10-29-2020 06:58 AM
AndrewIngall1
Any one able to help with a label expression query.
I have three attributes which i need to be able to stack and centre justify.  I am able to stack them and they have a left justification but for the life of me whatever i try i can no get it to work.
Below is the code i have.
(+$feature.DD + TextFormatting.NewLine + $feature.Direction + TextFormatting.NewLine + $feature.Distance)
Robert_LeClair
Esri Esteemed Contributor
Andrew - yes this can be done.  In the Label Class properties->Position under the Stack parameters, there's a Horizontal Alignment option you can set for Constrain Center.  This will center justify your stacked label.  See the image below.
