ArcGIS Pro Geoprocessing Pane bug?
1942
11-15-2016 09:56 AM
MikeFuller2
I have been trying to use geoprocessing tools in the geoprocessing pane in Pro 1.3.1, and keep getting error messages; however, when I perform the task using the python console, it works fine.
More specifically, I was trying to use the Add Join tool, and kept getting error messages of "Invalid Primary Key" when using the pane, but no issues when using python. I also had error 000229 with the Remove Join tool: "Cannot Open [layer]", but again, I had no issues when performing the task with python.
Are there any known issues relating to anything I experienced?
Mike
Tags (1)
MaribethPrice
Did you try closing and restarting Pro?  I find that it takes care of a lot of puzzling behavior like this.
MikeFuller2
Restarting seemed to fix it. Thanks!
