ArcGIS Pro crashed when creating a spectral profile of a multi-band image
2667
05-28-2023 07:17 PM
Labels (2)
Zihao_Zheng
I found this bug in several versions of ArcGIS Pro. When you trying to create a spectral profile of a multibands image or sth like that, the right panel of Pro appears with the following result and then loses its response.
Here, arcgis pro crashed...
CorrineCoakley
I'm running 3.3 and having the same issue. I fixed it by upgrading my Windows Display Graphics options, but now it just keeps spinning its wheel and never generates a chart. Has anybody has any progress on this in the past year?
TheodrosWoldeyohannes
Have the same issue too. I'm running 3.3.1. I have ran into this issue over the years in different versions on multiple machines. I have noticed it works on a PC with only a CPU running integrated graphics, but also an old laptop running an Intel i7 and Nvidia 960. Tested on machines with AMD CPU/GPU also. No apparent consistence or cause for when the bug will occur. I am quite annoyed that ESRI has not addressed this issue that has exited for a few years now.
AnthonyLEBRIS
Hi !
I have the same problem using the ArcGis Pro 3.6 version.
How to solve the problem ?
Thanks
agoerzen
I'm also having this issue on 3.6.1 but only when I connect my laptop to an external monitor.
Laptop->HDMI->Monitor: 100% bug rate when opening Spectral Profile chart properties.
Laptop standalone: 0% bug rate when opening Spectral Profile chart properties.
