arcgis pro clone environment failed
1053
11-26-2023 01:01 AM
Labels (2)
무영임
클론 환경을 만들려고 합니다
그런데 이 오류만 났어요
도와주세요...
[I 17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\share\jupyter\nbextensions\latex_envs\doc\example. png
[I 17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\share\jupyter\nbextensions\latex_envs\doc\header .tex
[I 17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\kwon gyeongwon\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\share\jupyter\nbextensions\latex_envs\doc\ IEEEtran.bst
[I 17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\share\jupyter\nbextensions\latex_envs\doc \LaTeX_envs_menu.png
[I 17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\share\jupyter\nbextensions\latex_envs\ doc\latex_env_doc.html
[I 17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\share\jupyter\nbextensions\latex_envs \doc\latex_env_doc.ipynb
[I 17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\share\jupyter\nbextensions\ latex_envs\doc\latex_env_doc.tex
[I 17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\share\jupyter\nbextensions \latex_envs\doc\main_toolbar.png
[I 17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\share\jupyter\ nbextensions\latex_envs\doc\README.md
[I 17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\share\jupyter \nbextensions\latex_envs\doc\Toggles.png
[I 17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\share\ jupyter\nbextensions\latex_envs\doc\latex_env_doc_files\latex_env_doc_23_2.png
[I 17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone \share\jupyter\nbextensions\latex_envs\doc\latex_env_doc_files\latex_env_doc_24_2.png
[I 17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro- py3-clone\share\jupyter\nbextensions\latex_envs\doc\latex_env_doc_files\latex_env_doc_26_2.png
[I 17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData\Local\ESRI\conda\envs \arcgispro-py3-clone\share\jupyter\nbextensions\latex_envs\doc\latex_env_doc_files\latex_env_doc_27_2.png
[I 17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\share\jupyter\nbextensions\latex_envs\doc\latex_env_doc_files\ latex_env_doc_41_0.png
[I 17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\share\jupyter\nbextensions\latex_envs\doc \latex_env_doc_files\latex_env_doc_42_0.png
[I 17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\share\jupyter\nbextensions\ latex_envs\doc\latex_env_doc_files\latex_env_doc_43_0.png
[I 17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\share\jupyter \nbextensions\latex_envs\doc\latex_env_doc_files\latex_env_doc_44_0.png
[I 17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\ share\jupyter\nbextensions\latex_envs\doc\latex_env_doc_files\latex_env_doc_45_0.png
[I 17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3 -clone\share\jupyter\nbextensions\latex_envs\doc\latex_env_doc_files\latex_env_doc_46_0.png
[I 17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData\Local\ESRI\conda\envs\ arcgispro-py3-clone\share\jupyter\nbextensions\latex_envs\doc\latex_env_doc_files\latex_env_doc_47_0.png
[I 17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData\Local\ESRI\conda \envs\arcgispro-py3-clone\share\jupyter\nbextensions\latex_envs\doc\latex_env_doc_files\latex_env_doc_48_0.png [I
17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData\Local\ ESRI\conda\envs\arcgispro-py3-clone\share\jupyter\nbextensions\latex_envs\doc\latex_env_doc_files\latex_env_doc_49_0.png [I
17:48:44 InstallContribNbextensionsApp] 최신: C:\Users\권경원\AppData \Local\ESRI\conda\envs\arcgispro-py3-clone\share\jupyter\nbextensions\latex_envs\doc\latex_env_doc_files\latex_env_doc_50_0.png [I 17:48:44 InstallContribNbextensionsApp] 최신: C:\
Users\권경 won\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\share\jupyter\nbextensions\latex_envs\doc\latex_env_doc_files\latex_env_doc_51_0.png [I 17:48:44 InstallContribNbextensionsApp] 최신: C:\
Users \권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\share\jupyter\nbextensions\latex_envs\doc\latex_env_doc_files\latex_env_doc_52_0.png [I 17:48:44 InstallContribNbextensionsApp] - 검증 중:
ok
[ I 17:48:44 InstallContribNbextensionsApp] C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\etc\jupyter에 구성할 jupyter_contrib_nbextensions 항목 설치
활성화 중: jupyter_nbextensions_configurator
- 구성 작성 중: C:\Users\kwon gyeongwon\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\etc\jupyter - 유효성 검사 중... jupyter_nbextensions_configurator 0.4.1 ok 노트북 활성화 중
nbextension
/ config_menu/main...
트리 nbextension 활성화 nbextensions_configurator/tree_tab/main...
[I 17:48:44 InstallContribNbextensionsApp] 노트북 확장 활성화 contrib_nbextensions_help_item/main...
[I 17:48:44 InstallContribNbextensionsApp] - 유효성 검사 중: ok
[I 17:48:44 InstallContribNbextensionsApp] - 구성 편집: C:\Users\kwon gyeongwon\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\etc\jupyter\jupyter_nbconvert_config.json [I
17:48:44 InstallContribNbextensionsApp] -- nbconvert 템플릿 경로 구성
[I 17:48:44 InstallContribNbextensionsApp] -- nbconvert 전처리기 구성
[I 17:48:44 InstallContribNbextensionsApp] - 구성 작성: C:\Users\권경원\AppData\Local\ESRI\ conda\envs\arcgispro-py3-clone\etc\jupyter\jupyter_nbconvert_config.json
[I 17:48:44 InstallContribNbextensionsApp] -- 업데이트된 구성 파일 작성 C:\Users\kwon gyeongwon\AppData\Local\ESRI\conda\envs \arcgispro-py3-clone\etc\jupyter\jupyter_nbconvert_config.json
노트북 확장 기능 collapsible_headings/main 활성화 중...
- 검증 중: ok
복사 중: repr_style/main -> C:\ProgramData\jupyter\nbextensions\main
역추적(가장 최근 호출 마지막 😞
파일 "C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\Scripts\jupyter-nbextension-script.py", 9행, <module>
sys.exit (main())
파일 "C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\lib\site-packages\jupyter_core\application.py", line 269, launch_instance
return super().launch_instance(argv=argv, **kwargs)
파일 "C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\lib\site-packages\traitlets\ config\application.py", 982행, launch_instance
app.start()
파일 "C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\lib\site-packages\ 노트북\nbextensions.py", 972행, start
super().start()
파일 "C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\lib\site- packages\jupyter_core\application.py", 258행, start
self.subapp.start()
파일 "C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\lib\ site-packages\notebook\nbextensions.py", line 702, start
self.install_extensions()
파일 "C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\lib\ site-packages\notebook\nbextensions.py", 라인 675,install_extensions에서
full_dests = install(self.extra_args[0],
파일 "C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\lib\site-packages\notebook\nbextensions.py" , 191행, install_nbextension
_maybe_copy(src, full_dest, logger=logger)
파일 "C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\lib\site-packages\notebook \nbextensions.py", 1030행, _maybe_copy
shutdown.copy2(src, dest)
파일 "C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\lib\shutil. py", line 444, copy2
copyfile(src, dst, follow_symlinks=follow_symlinks)
파일 "C:\Users\권경원\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\lib\shutil.py ", 264행,
open(src, 'rb')을 fsrc로 사용하는 copyfile:
FileNotFoundError: [Errno 2] 해당 파일 또는 디렉터리가 없습니다: 'repr_style/main'
노트북 확장 프로그램 repr_style/main을 활성화하는 중...
- 유효성 검사 중: ok
' chcp'\ufffd\ufffd(\ufffd\ufffd) \ufffd\ufffd\ufffd\ufffd \ufffd\u01f4\ufffd \ufffd\u073a\ufffd \ufffd\ufffd\ufffd\ufffd, \ufffd\ufffd\ufffd\ufffd\ ufffd\ufffd \ufffd\ufffd \ufffd\u05b4\ufffd \ufffd\ufffd\ufffd��\u05f7\ufffd, \ufffd\u01f4\ufffd \ufffd\ufffd\u0121 \ufffd\ufffd\ufffd\ufffd\ufffd\
ufffd \ufffd\u01b4\u0574\u03f4\ufffd.
반환 코드: 1
정리 중...
대상 폴더가 제거되었습니다.
ThomasPlazek
안녕하세요 무영임,
환경을 복제하려면 python 명령 프롬프트를 사용해야 합니다. 이를 수행하는 명령은 다음과 같습니다.
Python 명령 프롬프트를 관리자로 실행합니다.
시작 아이콘을 클릭합니다.
ArcGIS 폴더로 이동합니다.
Python 명령 프롬프트 > 자세히 > 파일 위치 열기를 마우스 오른쪽 버튼으로 클릭합니다.
Python 명령 프롬프트를 마우스 오른쪽 버튼으로 클릭하고 관리자 권한으로 실행을 클릭합니다.
다음 명령을 입력하여 사용 가능한 모든 Python 환경을 검색합니다:
conda env list
복제할 Python 환경의 이름을 식별합니다.
다음 명령을 입력하여 환경을 복제합니다:
conda create --clone <environment to clone>  --name <new environment name> --pinned
Or
conda create --clone <environment to clone>  -p <path><new environment name> --pinned
클론은 까다로울 수 있습니다. 이게 도움이 되길 바란다!
