ArcGIS Pro cannot handle XYZ layer (TMS) with negative parameter
1493
11-14-2023 12:24 AM
TomGeo
I am trying to add a TMS layer to ArcGIS Pro as well as to a web map in our Enterprise Portal, without success.
The service comes with a negative value for the row parameter. When I try to add this layer to a map in ArcGIS Pro then I get the following error message.
If I remove the minus in front of the row parameter, then the service is loaded, but is unusable as the following screenshot is trying to illustrate.
Adding the layer to QGIS works without a problem... just the wrong platform 😅
The url for the service is: https://map02.eniro.no/geowebcache/service/tms1.0.0/nautical/{z}/{x}/{-y}.png
and it would be really nice if some of you have a solution. Especially for getting the data into web maps.
- We are living in the 21st century.
GIS moved on and nobody needs a format consisting out of at least three files! No, nobody needs shapefiles, not even for the sake of an exchange format. Folks, use GeoPackage to exchange data with other GIS!
