ArcGIS Pro - Can't publish within a Network Enviornment
5450
01-12-2015 06:34 PM
JohnPlunkett
Hi there,
I am working with a customer that can't publish layers from ArcGIS Pro within a Fire walled Network environment.
They can however publish the same layer to AGOL from Desktop within the same network.
Take the computer outside the network and everything works as expected.
The Fiddler logs indicate that no traffic is detected when publishing Pro.
Has anyone come across this before?
Any advice is appreciated.
John
JohnPlunkett
For reference this has been resolved, the customer had to work with their IT department to ensure that these sites was whitelisted.
*.arcgis.com
*.arcgisonline.com
*.amazonaws.com
  *.esri.com
Joanne Parkinson
JoanneParkinson
Hi John,
I will message you directly so we can figure out the issue.
Joanne
JoanneParkinson
Hi John,
Not sure if you got my message or not...
Are you using proxy server or proxy script? If so, this may be what's causing your problems. We're trying to reproduce the issue here. Can you provide any additional details please?
Please feel free to message me directly.
Joanne
JohnPlunkett
*.arcgis.com
*.arcgisonline.com
*.amazonaws.com
  *.esri.com
Joanne Parkinson
