ArcGIS Pro Calculate Field Using Python - Return String if Field is Null not working
1418
5
05-29-2025 08:47 AM
SaranehSFitzgerald
def RampQA(ramp_type😞
    if ramp_type is None:
       return "Ramp type is blank"
This hasnt worked, but feels like it should be simple... "ramp_type" is a string field. This calculation would return an error in a completely different field. Instead of returning "Ramp type is blank" it just returns Null in that field and results in this warning message:
WARNING 002858: Certain rows set to NULL due to error while evaluating python expression: File "<string>", line **, in RampQA
DavidPike
MVP Notable Contributor
Can you post a screengrab of the expression and codeblock from Pro?  Also your text got formatted into an emoji.
KenBuja
MVP Esteemed Contributor
Are the values Null, an empty string (""), or a space (" ")?
AustinAverill
This is likely the root. Trying to verify "blank" values in field calculator is a mess.
RichardHowe
Your expression for the above code block would need to be:
RampQA(!ramp_type!)
JoshuaBixby
You don't even need a code block for this, a Python 6.13. Conditional expressions in the expression block will do the trick:
"Ramp type is blank" if !ramp_type! is None else !ramp_type!
