Arcgis Pro 3.6 ignoring printer margins since update from 3.5
1464
12-09-2025 04:12 PM
HansRasmussen
Hello Hivemind
Ever since I've updated to 3.6, Arc has been ignoring printer margins and has been putting them at the top left.  When I print the plot gets shoved down and to the right.  PDF's are still good.  I've tried multiple printers.  I've tried using the Page from Printer page setup with margins and without.
Anybody else, or have any ideas?
Thanks
H
Tags (1)
DanielFox1
@HansRasmussen Thanks you for reporting this, I believe that this is a defect BUG-000181320 I would encourage you to log a support case with your distributor so technical support can confirm and attach this defect to your case giving you visibility of the bug as it goes through its life cycle.
DanPatterson
MVP Esteemed Contributor
And the link is...
printer margins bug
for those that want to subscribe to it
... sort of retired...
QDSGIS
We are having the same issues and appreciate your comment as I thought it was a windows driver issue and was alone.  Will create a ticket as well.
HansRasmussen
Not fixed in 3.6.1  😞
DanPatterson
BUG-000181320 for ArcGIS Pro
still in Product Plan, you can subscribe to it, if you haven't, to get notification when it is fixed
