ArcGIS Pro 3.4.2: The “Make Raster Layer” tool appears not to have a browse option to specify where to store the output,
1161
05-03-2025 09:51 AM
JamalNUMAN
Legendary Contributor
In the screenshot below, the “Make Raster Layer” tool does not seem to provide a browse option for defining the output location.
What could be the issue here?
Jamal Numan
DanPatterson
MVP Esteemed Contributor
because it is a layer for the map and it is temporary
Make Raster Layer (Data Management)—ArcGIS Pro | Documentation
you can make a *.lyrx file using
Save To Layer File (Data Management)—ArcGIS Pro | Documentation
... sort of retired...
JamalNUMAN
Hi Dan,
Then what could be the reason behind the error shown in the screenshot below? What’s wrong with the path and name? They should be okay.
Jamal Numan
HamedHadad
you have to put the entire path to the image for this tool or it won't recognize it, try clicking on the input raster, if no path was written go to browse and locate the image with its path
