ArcGIS Pro 3.4.2: Selecting “Classify” as the primary symbology causes the raster to disappear,
1295
04-22-2025 01:53 AM
JamalNUMAN
Legendary Contributor
I couldn’t figure out why this happens, especially since the raster displays correctly when using “Stretch,” “Discrete,” or “Unique Values” as the symbology.
What could be the issue here?
Jamal Numan
DanPatterson
MVP Esteemed Contributor
Problem: The Classify Symbology is Not Available for Raster Datasets in ArcGIS Pro
but people have been experiencing symbology issues of late,
Make sure you have calculate statistics for your rasters before using them
... sort of retired...
JamalNUMAN
In the screenshot below, using “Classify” as the primary symbology works fine. In which cases does it work, and in which does it not?
Jamal Numan
JamalNUMAN
Setting the coordinate system of the source imagery to be “unknown” appears to resolve the issue where the “classify” works successfully.
The data is attached
Jamal Numan
