ArcGIS Pro 3.3 issues with exporting
5346
7
05-22-2024 09:23 AM
RyanLinhart
Ever since switching to 3.3 my organization has been experiencing difficulties exporting layouts. Specifically, when we export a layout, the finished product is missing some of the map features. It looks like the layer had been disabled but, it has not. My organization does have one machine that is still using 3.2 and there have been no issues with exporting when we use that machine. This leads us to believe it is a bug with 3.3 because if we are able to export the same layer, in the same project, from a different computer with no issues and the only difference is one computer is on 3.3 and the other 3.2 it seems like a plausible conclusion. Has anyone else experienced issues similar to this?
I attached an example below. The file with Example in its name is what we get when we export the layout using 3.3 and the Corrected file is the same layout/project/layer using our 3.2 machine.
David_McRitchie
Hey Ryan,
It would be worth trying this with a few new layers and layout files. If you get the same issue then it absolutely would be worth raising a Support Case as this could be a defect with 3.3.
Many thanks,
David
Esri UK -Technical Support Analyst
HollyTorpey_LSA
We have not noticed any changes in our PDF exports since updating to 3.3. Here are the export settings we use in case that helps you troubleshoot:
- Holly
NedMeinke
I'm having exactly the same issue with whole layers and features, missing. Also any selected or highlighted features don't show up?
RudyRuiz
any update on a fix for this yet?
having this issue on GisPro 3.4.0
Jhorner
We have been having these same issues since upgrading from 3.2 to 3.3.
GISJess
I also experiencing this on 3.4.2 and in the newest update. I am exporting a series maps in JPEG. The maps contain a lot of veg polys, and a lot of text in the legend. Some polygons are not filled in and the legend gets wonky in some of the exports. It seems to be very random. I've been able to get the layouts to export correctly just by exporting the map over and over.
GeorgiannaStrobin
This is happening for me ONLY when exporting PDF files in 3.3.2.
