ArcGIS Pro 3.3.4 QueuedTask.Run(() => does not start immediately
688
02-25-2025 04:31 PM
RichardDaniels
MVP Regular Contributor
Has anyone encountered this issue and have a better work around?
Many of the commonly used methods in ArcGIS Pro SDK are required to be run on the 'MCT' thread. The code is wrapped in a QueuedTask.Run block and in most cases, we need to Wait for the result before continuing processing. This is often done with Task.Wait(). However, I've recently ran into a situation where Task.Wait throws an ERROR because the task has a status of TaskStatus.WaitingForActivation. Is this a known issue?
Task t1 = QueuedTask.Run(() =>
try { //do some long running work }
catch (Exception eX)   { // handle the error }
//code added to prevent error
while (t1.Status==TaskStatus.WaitingForActivation)
Thread.Sleep(500);
loopCount++;
if (loopCount > 22) // 11 seconds max wait time
     break;
t1.Wait();
