ArcGIS Pro 2.7: How to select polyline feature type from AutoCAD (dwg file)?
1718
01-22-2021 12:18 AM
JamalNUMAN
Legendary Contributor
I couldn’t figure out why the “select” tool is not able to select the polyline feature type from AutoCAD (dwg file)
Sample data is attached
Jamal Numan
DanPatterson
MVP Esteemed Contributor
Select Data (ModelBuilder)—ArcGIS Pro | Documentation
That tool? From the help it seems to be looking for a
 folder, geodatabase, feature dataset, or coverage.
It isn't clear which one since you are using cad
... sort of retired...
DanPatterson
JamalNUMAN
Thank you Dan for the help. It works fine
Jamal Numan
