Arcgis Pro 2.5 - Import table Issue
4013
10
02-26-2020 03:52 PM
RickeyFight
I just opened a pro project that was created pre 2.5 upgrade. I can see my data as expected.
When I try to re add that table to that project or any other made after the upgrade we get an error.
FAQ: What characters should not be used in ArcGIS for field names and table names?
After looking into it, I believe that the error is because pro is adding quotes to field names. Only on the layers that have a _ before hand.  This did not happen in a pre Pro 2.5 project and does not happen in desktop products. I downgraded to 2.4 and the table added without the quotes.
We do not have access to the database and cannot change the field names.
Any suggestions on a work around?
JoeBorgione
What is the source of the table and how are you connecting to it?
That should just about do it....
RickeyFight
Joe Borgione
A table from a SQL server.
DanPatterson_Retired
And maybe it is the new normal...
although the applicable software list is ancient
Software: ArcGIS-ArcEditor 9.3.1, 9.3, 9.2, 9.1, 9.0, 10 ArcGIS-ArcInfo 9.3.1, 9.3, 9.2, 9.1, 10 ArcGIS-ArcView 9.3.1, 9.3, 9.2, 9.1, 9.0, 10
From your link
Do not start field or table names with an underscore or a number.
RickeyFight
Dan Patterson
I am not sure why it was created that way but I cannot change the field names on the database at this point.
JoeBorgione
There is a new sql odbc driver that took care of excel and sql problems for me once I installed it:
https://community.esri.com/thread/245676-new-error-with-excel-to-table?commentID=898660#comment-8986...
RickeyFight
Joe Borgione
I installed the new driver and it did not work.
Unfortunately we are not running SQLite.
JoeBorgione
I'm  not using sql lite either.
ThomasColson
Just because it worked in previous versions, doesn't mean its supported. Try running Validating table and field names in Python—ArcPy Get Started | Documentation
 Also see
Fundamentals of adding and deleting fields—Help | Documentation
Naming Stuff In ArcGIS - USGS OEI/Enterprise GIS - myUSGS Confluence
When I try to create an attribute in 2.5 starting with "_toast", not only does it create "_toast", "f_toast" gets created as well, which is odd. Perhaps this is one of the several new bugs that were introduced with 2.5.
I recommend opening a case with tech support. I think you're out of luck on the quotes thing, but I'm curious as to their response both on existing fields created pre-2.5 that start with "_", as well as what's going on when you create a field in 2.5 starting with "_" and why a second one gets created with "f_".
ThomasColson
And...when you initially submit your case, please include EXACT steps to reproduce
  • What version of SQL server?
  • What OS is the SQL server on?
  • What type of authentication is SQL server using?
    • How are clients authenticating?
    • How is SQL authentication with the OS? Local System Account? Domain Account? If a domain account, is Kerberos enabled?
  • How was the feature class initially created? If with ESRI software, what version? If not ESRI software, exactly how did this table get into SQL?
  • Is the feature class using Geography or Geometry storage?
  • What is the projection of the feature class?
  • Is archiving or versioning enabled?
    • If versioning, what type? Same error after compressing all edits to default?
    • If archiving, same error when disabling?
  • Is editor tracking enabled?
  • What Operating system is Pro 2.5 installed on?
  • When was the last time you updated all of your hardware drivers?
  • Are you meeting ArcGIS Pro 2.5 system requirements—ArcGIS Pro | Documentation  and what is the result of http://www.systemrequirementslab.com/Client/Standard/?apikey=50F41142-39B0-4061-97C2-BA7B7FE43D0E&re...
  • Is the feature class published as a feature service?
