ArcGIS Pro 2.5: “Create TIN” tool appears not have drop down menu for height field and type,
2163
04-02-2020 11:32 PM
JamalNUMAN
Legendary Contributor
I observed that “Create TIN” tool appears not have drop down menu for height field and type as it used to be in ArcMap
Jamal Numan
DanPatterson_Retired
Select the tool, add to model
select a points file... Note!  there is no file called "Elevation" which makes me wonder if only finds one file AND it is named Elevation or Z, it will be used as the default.
Note, I get the drop-down choice list
Try with some random point file that does NOT have elevation or Z in it, BUT has more than 1 non-id or shape field (like mine) and see what happens
Or if that doesn't work, just follow my process and see if that makes a difference
PS!!!
You have 2 files to use... dump 1 for now, since adding 2 point files at once, may impact the drop-down capabilities of the tool.
Add one point file at a time, set its parameters, then add another featureclass for the next file
JamalNUMAN
I figured out that the issue here is related to activating some extensions.
Jamal Numan
When it is "user error" you don't mark your own answer correct, you use "Assumed Answered"
Michelle Mathias‌  I have corrected this
