ArcGIS Pro 2.4 Open Dialog Box
1756
07-01-2019 01:30 AM
SunilTerkar
I have been experiencing navigation issue in Add data dialog box. Prior to 2.4, in dialog box while navigating between directory or file by pressing first letter key of directory/file name, cursor used to jump to that directory or file but now it is not doing so. I have to manually scroll using the mouse to select the directory or file. It is pain when you have large number of directories or files to navigate.
Sunil Terkar
KoryKramer
Esri Esteemed Contributor
Are you sure the Add Data dialog box is in focus?
This is ArcGIS Pro 2.4:
KoryKramer
SunilTerkar
Thanks Kory, after re-installing ArcGIS Pro, dialog box navigation works as intended.
