ArcGIS Pro 2.1.0: Remove Subtype failed with error
7274
11
02-22-2018 12:34 AM
AbhijeetKulkarni
Hi all,
I am using ArcGIS Pro 2.1.0 with utility network data model. I have added couple of subtypes for assembly FC. If I try to delete one Subtype using 'remove subtype' tool, OR with 'create/manage' pane of subtype and save it, it fails with below error.
ERROR 002140: The subtype is required by utility network. Failed to execute (RemoveSubtype).
There are no custom domains assigned to it. Am I missing something to remove/change before removing subtype?
xander_bakker‌
DavidHoy
The reason I ask for more guidance is that I have been led astray by the Help documentation
Create a water utility network—Get Started | ArcGIS for Water
in this page it provides the following order of implementation
from the last step - it links to
Tools for configuring a utility network—ArcGIS Pro | ArcGIS Desktop
this describes using the Utility Network Tools Toolbox and the Database Management Tools Toolbox
- nowhere along this path does it indicate that schema changes should be made in the Asset package prior to step 4.
thus my call for a best practices type paper
HowardCrothers
Thank you for the feedback David Hoy‌, we will use it to update the documentation.
