ArcGIS Pro 2.0 | How to run geoprocessing tools in batch mode?
1186
01-23-2018 12:59 AM
VincentLaunstorfer
In regular ArcGIS Desktops application, such as ArcToolbox 10.5.1, it is easy to run a tool in batch in order to input multiple files. It is a simple right-click and select Batch.
In ArcGIS Pro, I cannot find the equivalent! Is it possible to run geoprocessing tools in Batch mode in Pro?
Asrujit_SenGupta
MVP Regular Contributor
There is presently no way to use the Batch mode for geoprocessing tools in ArcGIS Pro.
Idea that is Under Consideration:
Batch processing in ArcGIS Pro
PeteCrosier
I don't think Pro has batch processing in that way - you could achieve something similar using Model Builder or Python.
Asrujit_SenGupta
BruceHarold
Hi, Pro 2.1 adds new iterators in ModelBuilder to help with batch processing scenarios:
Examples of using iterators in ModelBuilder—Tools | ArcGIS Desktop
