ArcGIS Pro 2.0 Bugs?
1470
11-01-2017 05:00 AM
LindaRadomile
Hello All,
I am curious if anyone is having similar issues as I am with Pro 2.0.  Has anyone else experienced any of the following:
1. projects crashing
2. definition queries are splitting clause values (ie 'Doe, John' becomes 'Doe', 'John') I seem to be having alot of issues with Pro deciding what I want my IN queries to be - it will overwrite what I enter if I use the SQL window or the clauses
3. Projects becoming inaccessible and not opening - receiving an error window "ArcGIS Pro has stopped working..."  Usually if I restore the last saved back up it fixes the problem, but obviously this is not an appropriate work around and causes loss of work and time. Ive had this issue with 2 projects so far.
Please share if you've had have similar issues or advice.  Thanks!
JacquelinePursell
I also am having query problems in the last several versions of Pro.  I queried the same layers multiple times on different days and versions and machines in both Pro and ArcMap and only ArcMap was correct!  I have not seen a single definition query or select by attribute work properly!
