I am trying to publish a web layer after installing 3.7 and I keep getting a staging failed error. I have attempted to address the issues that appear in the log (attached) but I haven't had any luck.
For the consolidation error, I double checked the sources for each layer and all of them are linked correctly. For Error 004017, I cut down our naming convention to the barest minimum and I receive that error regardless of the pathname length.
Is anyone experiencing this issue or had success resolving it?
Thanks in advance.
In reviewing Esri Support cases, there was a recent case using ArcGIS Pro 3.7 where there was an incompatibiilty issue with an Xtools Pro Add-in. Do you have XTools installed by chance? If so, disable it and try again.
Maybe related (maybe not):
ArcGIS Pro 3.7 Moves to .NET 10
001270: Consolidating the data failed.—ArcGIS Pro | Documentation
Thank you so much! That worked.
I disabled my XTools and still get the "Staging Failed" error.
