I have a numerical attribute field containing integer values and would like to have the label expression display a corresponding value for each integer. I have created a dictionary representing these values.
However, the label expression dialogue indicates an error in line 2: Invalid Key. I cannot see anything wrong with the format of the dictionary based on other examples found within the forums.
The Arcade expression is shown below.
var stuff = {
0: "SCC",
101: "SEP",
4: "CLT",
23: "CGS",
8: "CTR",
7: "CTH",
14: "DSW",
9: "ECT",
5: "FTH",
21: "GPS",
10: "GSL",
3: "ITH",
22: "ITS",
13: "ISH",
20: "OSR",
17: "PTC",
26: "PCT",
24: "SAL",
18: "STC",
15: "SWR",
19: "STR",
6: "TFA",
12: "3SS",
11: "2SS",
100: "GPE",
25: "WHI",
102: "RET",
103: "TSI",
104: "POL"
var keyField = "Type"; //this is the attribute field with the integer values
var lookupKey = $feature[keyField];
var lookupResult = Dictionary(stuff)[lookupKey];
Solved! Go to Solution.
A key in the dictionary must be a string, not a number. You'll have to convert your field value to a string, in addition. Here's an example that works.
var stuff = {
"0": "SCC",
"101": "SEP",
"4": "CLT",
"23": "CGS"
var test = Text(0);
var lookupResult = Dictionary(stuff)[test]
Not sure why an arcade expression would work in AGO and not in Pro, but I've come up with a different way to write this that is working in Pro:
var stuff = {
"0": "SCC",
"101": "SEP",
"4": "CLT",
"23": "CGS",
"8": "CTR",
"7": "CTH",
"14": "DSW",
"9": "ECT",
"5": "FTH",
"21": "GPS",
"10": "GSL",
"3": "ITH",
"22": "ITS",
"13": "ISH",
"20": "OSR",
"17": "PTC",
"26": "PCT",
"24": "SAL",
"18": "STC",
"15": "SWR",
"19": "STR",
"6": "TFA",
"12": "3SS",
"11": "2SS",
"100": "GPE",
"25": "WHI",
"102": "RET",
"103": "TSI",
"104": "POL"
return stuff[Text($feature.Type)]
var stuff = {
"0": "SCC",
"101": "SEP",
"4": "CLT",
"23": "CGS"
var test = Text(0);
I should have mentioned I tried that as well but when doing this I'm given an error of field not found. I know the format for Arcade attribute labels is $feature.fieldname
var stuff = {
"0": "SCC",
"101": "SEP",
"4": "CLT",
"23": "CGS",
"8": "CTR",
"7": "CTH",
"14": "DSW",
"9": "ECT",
"5": "FTH",
"21": "GPS",
"10": "GSL",
"3": "ITH",
"22": "ITS",
"13": "ISH",
"20": "OSR",
"17": "PTC",
"26": "PCT",
"24": "SAL",
"18": "STC",
"15": "SWR",
"19": "STR",
"6": "TFA",
"12": "3SS",
"11": "2SS",
"100": "GPE",
"25": "WHI",
"102": "RET",
"103": "TSI",
"104": "POL"
// Look up the value based on the key from the field
return lookUpResult;
Here's an example using the sample dataset in the Playground (with the first key changed to "1" to get a result)
// Returns the first feature in the layer
var feat = First(
// Fetches features from a public portal item
FeatureSetByPortalItem(
Portal("https://www.arcgis.com"),
// portal item id
"7b1fb95ab77f40bf8aa09c8b59045449",
0, // layer id
["*"], // fields to include
false // include or exclude geometry
var stuff = {
"1": "SCC",
"101": "SEP",
"4": "CLT",
"23": "CGS"
var keyField = 'HasData'
var lookupKey = Text(feat[keyField]);
return Dictionary(stuff)[lookupKey]
I noticed that and i'm still getting the same error about field not found. Perhaps this is an issue with the label expression builder? I'm trying to fetch attributes with that interface. (ArcGIS Pro 3.1.3)
You have to use the Expects function at the top of the script when using a variable for the field.
Expects($feature, "Type")
var stuff = {
"0": "SCC",
"101": "SEP",
"4": "CLT",
"23": "CGS"
var lookupKey = Text($feature[keyField]);
Ok new clues. I'm going to mark your other response as the solution since it got us to where we need to be, but the rest looks like we have found a potential bug.
A colleague tested for me and the expression works just fine in AGO. For the heck of it, I saved a copy of that layer in AGO with the working label expression and brought it into Pro. Labeling failed to work. Checked the expression and same error about field not found.
I tried to add Expects($feature, "Type")
and that returns a new error of invalid JSON. So everything works fine in AGO but there's a problem with this solution in Pro.
Thanks for everything!
var stuff = {
"0": "SCC",
"101": "SEP",
"4": "CLT",
"23": "CGS",
"8": "CTR",
"7": "CTH",
"14": "DSW",
"9": "ECT",
"5": "FTH",
"21": "GPS",
"10": "GSL",
"3": "ITH",
"22": "ITS",
"13": "ISH",
"20": "OSR",
"17": "PTC",
"26": "PCT",
"24": "SAL",
"18": "STC",
"15": "SWR",
"19": "STR",
"6": "TFA",
"12": "3SS",
"11": "2SS",
"100": "GPE",
"25": "WHI",
"102": "RET",
"103": "TSI",
"104": "POL"
Thanks for this Elisabeth!
I'm curious about the disparity between AGO in Pro in the implementation of Arcade regarding dictionaries now.
