Arcade DomainName not working in labels
559
01-27-2026 07:10 AM
FranziskaSumpf
I have my label set up to show the domain value as well as the domain description. However, more often than not, this does not work. There is no error returned, no notification. I just don't get the expected label.
This is my label expression:
And this is what I get – just the domain code, twice:
The label in this example should read "[99999] gelöscht/unbekannt"
Is anyone else experiencing these problems? I am currently on AGP 3.5.2, but I had the same problem with previous versions.
Tags (3)
KenBuja
MVP Esteemed Contributor
I am running v3.5.4 and am not seeing that issue
FranziskaSumpf
Hi @KenBuja , does it also work if the attribute is from a joined table?  Could you try this?
I just tried it on a layer without a join and it worked like a charm. So I can narrow it down to joined tables. Unfortunately that doesn't solve my problem, because I rely on joins a lot.
KenBuja
It also works when I join it with a table with domains
FranziskaSumpf
Thank you @KenBuja for testing! I hope an upgrade will solve this for me, too.
