Arcade Display Expression Builder
1980
06-28-2023 02:54 PM
JosephPilkington1
I am trying to create a simple Display Expression in Expression Builder using Arcade. I want the expression to return the Unit, unless it is null, if null I want it to then display Building, unless that is null, if null I want it to finally display the Room. So far, my expression returns Unit, but nothing past that. What am I doing wrong?
return $feature.Unit;
if(isempty ($feature.Unit)){
return $feature.Building
else if(isempty ($feature.Building)){
return $feature.Room
jcarlson
return will end your expression. Since that first line has a return that is not within a conditional block, it will always run, and your expression will end at line 1.
Just put that line in its own if section:
if (!IsEmpty($feature.Unit)) {
} else if (!IsEmpty($feature.Building)) {
} else if (!IsEmpty($feature.Room)) {
- Josh Carlson
Kendall County GIS
jcarlson
- Josh Carlson
Kendall County GIS
JosephPilkington1
Ah! Makes sense. Thank you!! I knew something was wrong, I just couldn't figure it out. Much appreciated!
