I was trying to copy past attribute from table to excel, it seems this option is not available in arc pro......right?
In ArcGIS Pro, use CTRL+SHIFT+C to copy selected records in attribute table, this allows to then paste in excel.
Shortcut keys for working with tables—ArcGIS Pro | ArcGIS Desktop
Pro isn't the same the same as map... the common thread is
http://pro.arcgis.com/en/pro-app/tool-reference/conversion/table-to-excel.htm
short cuts may exist, but the standard workflow is to use tools.
Hi Dan,
Thanks for the reply. I know about this tool but it is sometimes easy to just do copy paste instead of following many steps. I have found another tool on ribbon which is "Export Table" , but again it is same workflow to follow couple of steps ![]()
Anu
That's the problem with shortcuts, the standard methods get forgotten or ignored first. ![]()
Nice find! bookmarked
Thanks Evan....shortcuts are always helpful when you want to do quick work.
Į wonder why millennium-aged steps now have been changed?
New command in the attribute table will be coming to Pro 2.2 which will help with this workflow:
