Hello! I am reaching out to see if others are running into the same issue with the Append Tool. Prior to a recent update for ArcGIS Pro, I was able to use the Append Tool and control the fields that are being mapped from one dataset to another - now everything is greyed out (Add Fields and Remove) when selecting the Field Matching Type = "Use the field map to reconcile field differences." I can't use the Append Tool anymore as part of my field mapping effort to combine hundreds of datasets into one authoritative dataset. I have never had issues with this before and was able to remove the fields from the authoritative layer that do not currently exist in my source dataset.
One example is the GlobalID field. My source data does not have a GlobalID field nor do I want it to have one until it gets appended into my authoritative feature layer. Previously, I would take my source dataset, use the Append Tool, and then choose how to use the field map. I would remove the GlobalID as well as a few other fields that are not available in my source data that I am trying to append into my authoritative source layer. The fields that do not have an existing field in the authoritative dataset have a caution flag; however, I cannot remove these anymore and run the Append tool.
The Append tool has been one of my most used tools in ArcGIS Pro recently as part of this data management effort so this has a significant impact on my ability to combine the hundreds of datasets I am working with into one authoritative dataset. I have not found many helpful posts in the community.
Has anyone figured out how to restore the greyed out functions for the field mapping effort (Add Fields and Remove) or know of a work around that does not involve merging, etc.? Is there a setting that was changed for Append tool?
Any help is greatly appreciated! Thanks!
a series of reports on the Tech Support site, they might be worth having a look at, or if none apply, then open an issue would be your best option
Thanks for your response and providing these links! I looked into them a little more, but it doesn't seem to address my issue or provide a good solution or workaround on this bug. It seems like new function of the Append tool limits any remapping effort because it would now affect the schema from the authoritative layer with recent updates. It is unfortunate because of how much I use this tool to append many different datasets into an authoritative one. The append tool worked exactly as I needed it to in order to transfer data. The fields that couldn't be mapped would auto-populate with default field values, <null>, or unique IDs from the authoritative layer without affecting the schema.
It looks like I might have to go backwards in software until they fix this bug or I can find a different solution.
Thanks again for your suggestion!
Do i understand you are wanting the field mapping definition to only apply to a subset of the fields, and other fields should be ignored? but it doesn't work, unless all fields have a decision\mapping from the source?
The load data tool in ArcMap/Catalog allows users to ignore fields in the field mapping. The Append tool in ArcPro does not allow users to ignore fields in the "Use the Field Map to reconcile differences" field mapping type, I'm on version 3.4
This is does appear to be the same bug referenced above: BUG-000157944 for ArcGIS Pro - it's noted that it's "in the product plan". This along with a thousand other "bugs" that make the transition to Pro so frustrating for Desktop users.
Its odd that BUG-00015794 references pro version 3.1.1 but I have only experienced this issue with 3.4.2 and it worked fine in my previous 3.3.x versions.
In earlier version I would select on the fields with the yellow no match warning and delete them from the list but in the latest version of pro they will not delete.Screenshot 2025-03-04 111250.png
My program just freezes up when I try to append and use the field mapping. It happens as soon as I click on the icon for the field I want to map. I am on 3.4.2 also.
this is maddening. Why fix what wasn't broken and make it not-intuitive!
