locator in arcgis pro same cant recognize format in meter for x,y to zoon in (160500 390200)
what format should we use what setup we shoul do to make it work
In ArcGIS Pro 1.4, if the map units of the map view is set to meter and you enter the coordinates into the search box of the Locate pane you will get candidates returned from the XY Provider. Below is an example of the results from version 1.4.
