AGP - ArcGIS Pro missing .aprx and toolbox including FME Workbench tools.
1128
05-15-2022 08:00 PM
Labels (2)
Joo-raBaek
Hello, professionals.
Did anyone experience a problem that ArcGIS Pro project files are missing in a sudden?
I cannot reproduce the issue for now, but it happens occasionally on customer's PCs(several PCs in different customer sites).  The ArcGIS Pro version is 2.9.2 and serveal other versions also had same issues.
- Testing Completed:
ArcGIS Project files containing some tools created by Data Interoperability tool (FME Workbench function) are missing in a sudden.
This error happens without any error message in various customer sites with different ArcGIS Pro versions.
There is no Temp file or file left under Recycle bin. Only geodatabase files but nothing are left.
The customer found similar cases online.
There is no solution found after searching the Esri community and other online resources.
It seems like many users are experiencing identical problem.
1) https://community.safe.com/s/question/0D54Q00008B0QKOSA3/workspace-disappeared-from-my-local-drive-a...
2) https://community.esri.com/t5/arcgis-pro-questions/arcgis-pro-quot-project-not-found-quot-error/td-p...
3) https://community.esri.com/t5/arcgis-pro-questions/arcgis-pro-quot-project-not-found-quot-error/td-p...
Any bug is defected but it was hard to analyze when the proble happend exactly. One engineer from Esri recommended to gather logs using the Process Monitor, but the customer cannot install the program in her PC.
