After the ArcGIS Pro Model Builder references the in-line variables, it cannot overwrite the original feature classes
578
03-28-2020 01:07 AM
圈圈
The absolute path is used in the above figure, and the in-line variable is not added. At this time, although the output feature class with the same name is prompted, the model can still be run to cover the original feature class. However, if the in-line variable is added, the error warning that the output feature class already exists will appear and the model cannot be run? Following chart
Is there any solution?
