Adjust System Date dynamic text in print layout
622
01-13-2026 09:39 PM
AmberKelly
We have created a print layout template for use in our ArcGIS Enterprise Portal. We have added the System -> Current Time dynamic text value.
When viewed in ArcGIS Pro it all looks correct however once published to Portal and used to create a print the Date and Time values we are seeing are in UTC. We think this is due to the servers the Portal is installed on being in UTC (unfortunately this cannot be changed).
Is there a way I can add 10 hours to the UTC time/date to reflect our local timezone? I'm reading this can be done with Table Attribute -> Value but as our layout is a print template and has no layers, we are unable to use the Value dynamic text.
Thanks
Amber
JonM32
@AmberKelly
Maybe try this: <dyn type="expression" script="var currentTime = Now(); DateAdd(currentTime, 10, 'hours');" format="short|short"/>
If you publish this arcade statement in place of the current one your using, it may work how you want?
Let me know how it works out!
If this helps or is the solution, please consider a kudos or solution
Cheers,
Jon
If this response helps or is the solution to your post, please consider marking it as a solution
AmberKelly
Thanks for responding Jon 😊
Unfortunately that approach didn't work.
Cheers
Amber
