Adding year on to date field using field calculator
2600
08-26-2020 07:46 AM
DarrenDe_Lange
Hi there all
I am trying to automatically add a year, to a known date in a field, in to a newly, created field in the attribute table.
So if user enters today's date, the new field should show today's date + 1 year.
I tried this code in the field calculator of the attribute table = DateAdd('yyyy',[$feature.year],[$feature.date]) - but the field entry stays as 'NULL' even though the code is verified and pliable.
I am open to other suggestions if there is another work around, just needs to happen automatically when the user enters a new date (not sure if there is an ArcPy work around).
thank you for any assistance!
JoeBorgione
Not arcpy per se, but take a look a the datetime.timedelta() function in python.
That should just about do it....
