Adding time to basic hotspot analysis
3818
10
12-08-2020 11:33 AM
Ashok_kumarSankaranarayanan
Hello all, I am doing hotspot analysis for a disease in emergency department, I want to know whether i can add time to basic hotspot analysis and see weekly results for changing hotspots,because I don’t need 17 categories as given by emerging hotspot analysis,My aim is to find out for changing statistically significant hotspots for every week, Thank you all
Robert_LeClair
Esri Esteemed Contributor
At ArcGIS Pro 2.5 this is an Add-in to the core application.   At ArcGIS Pro 2.6 it's part of the core application I believe. You can download and install the Add-in here.
Robert_LeClair
Ashok - one way to do this is to use the Select Layer by Date and Time (Crime Analysis and Safety).  In the GP tool, set the Select by Date (Options) to "By Date Range" and set your week range.  Then run the Optimized Hot Spot tool on the selected features to get the Hot Spot for that week.  Hope this helps!
Thank you and really appreciate for providing me an idea, i shall work on it and update you,have a nice day
Robert_LeClair
You're welcome - let me know how it goes and if my suggestion resolves this question.  Have a nice day too!
Thank you Robert,I searched for the tool but i am not having it,I am using ArcGIS pro 2.5, Any other suggestions,how to get it ,Thank you
Robert_LeClair
Great,Thank you,Robert ,i shall get back,by checking how it comes out,Thank you again🙏
Dear Robert i used select layer by date and time, I did optimized hotspot analysis on my 3 months of data splitting into 10 days, it has come out well,thank you, I need to know if there is any other tool by which if can compare hotspot analysis layers to see the difference ,Thank again.
Robert_LeClair
There are some great "compare" geoprocessing tools in the Data Comparison toolset that may prove of interest to you.  What is your output data?  Vector or Raster?
Thanks for reply Robert, My data is a vector data, covid-19 point data,Let me know if there is any specific good data comparision tool, Thank you again
