Adding feature class and applying symbology in ArcGIS Pro using arcpy
19158
27
06-13-2018 09:40 PM
SeanHough
Using an arcpy script run from a toolbox, I want to import a feature class from a geodatabase into an ArcPro map and then symbolise that layer based on a lyrx file stored on disk. Here is a simplified version:
import arcpy, os
aprx = arcpy.mp.ArcGISProject('CURRENT')
m = aprx.listMaps('*')[0]
outputWorkspace = r"C:\Path\To\MyProject.gdb"
arcpy.env.workspace = outputWorkspace
out_fc = "fc_data"
out_fc_p = os.path.join(outputWorkspace, out_fc)
ref_lyrx = r"C:\Path\To\symbol_ref.lyrx"
m.addDataFromPath(out_fc_p)
out_fc_lyr = m.listLayers()[0]
arcpy.ApplySymbologyFromLayer_management(out_fc_lyr, ref_lyrx)
The script completes without error but no visible change is made to the symbology. Is this a bug? I've reviewed many similar questions but have been unable to resolve this.
TingDai
This method works! I am using 2.8.2. Thanks!
KeithMiller4
Both of these programmatic fixes work for me in the Python window within ArcGIS Pro. However, I can get neither of them to work as part of a Python Toolbox tool script.
MichaelLowry2
BUG-000106281 about this issue is apparently fixed for Pro SDK at release 2.3,
https://pro.arcgis.com/en/pro-app/get-started/release-notes.htm
but I still cannot apply symbology from a layer file to a layer in my map through a script tool in Pro.
I have tried both call methods:
arcpy.management.ApplySymbologyFromLayer(target_layer, symbology_layer)
arcpy.ApplySymbologyFromLayer_management(target_layer, symbology_layer)
And I have tried .lyr and .lyrx
I know it is a problem with Pro, because if I run the exact same script tool in ArcMap (10.3) it works properly.
Any information or suggestions?
DavidWilton
See my comment below. I still have a case open. I think it may have been closed for the net sdk but not python. Yet for some reason the complaint about python was attached as a duplicate of the pro issue and closed with it which is pretty frustrating. I don’t think two cases using different technologies should ever be considered a duplicate personally but not much we can do. I’m still pushing my case
BUG-000119907 - The Apply Symbology From Layer tool (arcpy.ApplySymbologyFromLayer_management) does not work if used in a python script from the tool box in ArcGIS Pro 2.3
LeandraGordon
Looks like they have a separate case open for just Python now: BUG-000108497: Running the Apply Layer Symbology tool as a script i..
by Anonymous User
Not applicable
Good morning. I have been working on applying symbology from layer without results. This needs to be implemented in a stand alone python script. Ultimately it will have to apply many lyrx files to matching feature classes, however I can not even get this to apply a single feature class on test data.
Has this bug been fixed?
Please let me know as soon as you can, thank you!!
Justine
JoshuaBixby
MVP Esteemed Contributor
This defect, BUG-000119907, is publicly logged:  BUG-000119907: The Apply Symbology From Layer tool does not work if..  You can check the current status and see the alternate work arounds.
by Anonymous User
Not applicable
Thanks for your speedy reply. I am trying to do this in a stand-alone python script & it is failing. The data does have the appropriate fields, data source is not broken, etc.
Do you have advice if this is a bug in stand alone scripts & work arounds for that?
Thank you,
Justine
RichardHowe
Interestingly I hit this issue whilst using the Apply Symboogy from layer GP tool within model builder. Setting the output as a parameter solved the issue. I'm not sure what the pythonic equivalent to that would be though
MichaelLowry2
The updateConnectionProperties solution did not work for me when running as a script. This workaround does:
current_project = arcpy.mp.ArcGISProject("CURRENT")
current_map = current_project.listMaps()[0]
symbology_layer = SymbologyPath + '\\FLO_scaled_graduated_symbol.lyrx'
new_lyr_file = arcpy.mp.LayerFile(symbology_layer)
new_lyr = new_lyr_file.listLayers()[0]
old_lyr = current_map.listLayers(original_network)[0]
old_lyr_name = old_lyr.name
new_lyr.updateConnectionProperties(new_lyr.connectionProperties, old_lyr.connectionProperties)
new_lyr.name = old_lyr_name
new_lyr_file.save()
current_map.insertLayer(old_lyr, new_lyr_file)
current_map.removeLayer(old_lyr)
However, I want to publish this tool and I cannot because as far as I can tell webtools cannot use "CURRENT".
By the way these are the other methods I have tried, none of which work in Pro but work fine in ArcMap:
1.
arcpy.ApplySymbologyFromLayer_management(inputLayer, symbologyLayer)
2. Using derived output (e.g. parameter 2):
arcpy.SetParameterAsText(2, inputLayer)
params = arcpy.GetParameterInfo()
params[2].symbology = symbologyLayer
3. Using derived output and pointing to the symbology file when setting script tool parameters.
