Add Control Points tool only works intermittently in ArcGIS Pro
1087
07-02-2020 06:09 AM
LeslieCooper
Currently using ArcGIS Pro 2.4 The tool stops working and I have to restart Pro each time I need to georeference using this tool which is a pain in the arse. It's not worked properly in previous versions and was hoping there was a fix for this version but no dice. The prompt turns into crosshairs as if it's working properly but clicking does not add a control point. Always works properly for first time I use it in a session, but after that it only works a few times per session max. Anyone else experiencing this?
