3D Mensuration (Volume) tools errors - Transformation is unavailable for the current image
410
03-05-2026 02:16 PM
Labels (2)
WesleyBryning
Recently I have been working on measuring the volume of some gravel piles in our gravel pits with drone imagery, but I have been coming across some oddities with using the Mensuration tools built into ArcGIS Pro (3.3.7 currently).
After creating a DSM, I am able to set that as the elevation and use it to measure volume with the mensuration tool with no problem, but if I switch out of the tool, when I return to use any of the 3D mensuration tools, I draw my polygon and then am met with an error as follows: "Transformation is unavailable for the current image." It gives me no further explanation and it keeps all my previous measurements in the results just fine.
About 75% of the time, restarting ArcGIS pro and reopening my project fixes this (after I again set the elevation data within mensuration options, another oddity that I have to do this every time I start the project) and I am once again able to make 3D mensuration measurements with no problem.  The other 25% of the time it reverts back to the Transformation error.Transformation_Error.PNG
The Mensuration tool is new to me, and it seems like it is just finicky and maybe underdeveloped in favor of developing the capability in other programs like ArcGIS Reality, but if anyone has had this and was able to find a fix, that would be great.
DanielFox1
Hi @WesleyBryning
It might be worth to try the following to see if your issue is resolved:
1. Move your DSM and imagery into a map (not a scene)
2. Re-assign the elevation dataset in Mensuration Options even if it looks correct
Imagery > Mensuration Oprtions > Elevation > Select your DSM
3. Ensure your DSM is a supported raster type
If you can I would consider upgrading Pro to make use of any fixes applied in the latest release, and also ensure that the Image Analyst extension is enabled.
I hope this helps somewhat
Mensuration Tools Are Disabled in ArcGIS Pro
Mensuration Options—ArcGIS Pro | Documentation
