1 line, attributes from many polygons....
1277
06-26-2023 12:49 PM
ThomasColson
MVP Alum
I feel like this is a simple task with an obvious solution....but they don't call me Captain Obvious for nothing...
I have a line feature class for which I wish to attribute every polygon the line(s) pass thru. For example, a line passes through many states, I can, with automation, write the name of every state it passes through (with commas) to a text field.
Can't be the first person to want to do this?
ClayDonaldsonSWCA
this can be done with spatial join and the join field mapping!
Spatial Join (Analysis)—ArcGIS Pro | Documentation
Join
A concatenation of source values. You can use a delimiter to separate multiple input values.
RhettZufelt
MVP Notable Contributor
As @ClayDonaldsonSWCA said, and here is a pretty good guide to that.  This is for ArcMap, but still the same procedure, you just have to hunt for the options in Pro.
R_
