Display Z-coordinate of the elevation surface along with the X- & Y-coordinates in the status bar if an Elevation Source Layer has been added.
@KentBuchanan - I'm using ArcGIS Pro 3.6.x and can see the Z-value in the status bar (bottom of the image) with a custom elevation source layer added (Elevation_clip1). See image below. The value changes as I move my mouse around in the local scene. What release of ArcGIS Pro are you using? And if this is not what you're looking for, please let me know those details.ArcGISPro36_ZValue.jpg
I think Kent is refering to the 2D map views and I agree they should show the z coordinate when an elevation source is in the map.
Z-coordinate is displayed in Pro 3D maps > Local Scene or Global Scene as in example posted by @Robert_LeClair .
@KentBuchanan Are you looking for the same information in 2D Map as well?
