User-Defined Topology Color in Editing Tools
3339
6
12-10-2020 08:02 AM
Status: Implemented
jcarlson
I love that I can adjust the color of my selection / editing. I do a lot of work with features which participate in a topology, but also with simple hosted feature classes which ought to be topologically consistent. I find myself working with vertices a lot, and being able to change the symbology of vertex points in the sketch is great!
My idea is a simple one: allow the user to adjust the symbology of the topology features in the same way. Currently with a topology tool active, it renders as a network of pink nodes and edges:
The color isn't bad if I'm working with a dark basemap and a single layer as pictured, but in other instances it can be hard to see, and I wish I could change it. Additionally, I'd love to make the nodes appear larger, or have them a slightly different color, or add a symbol outline to make them pop more. Like this! (This is just the layer's symbology being adjusted.)
6 Comments
Scott_Harris
Thanks for the suggestions @jcarlson . We have plans to implement a way to configure this in the near term.
Scott_Harris
by Anonymous User
I use the Reshape tool in Pro to edit line features. When I select a feature or edge to reshape, the selected line becomes very thick, and oftentimes I cannot see the imagery underneath that will guide my reshaping. This results in inaccurate editing and excess time spent re-reshaping.
I would love if the selected feature/edge width was reduced (or option to customize). In ArcMap, the selection becomes magenta but does not get wider, which is much easier.
Original symbology:
Thick symbology with reshape selection (using a topology):
jhirsch
Just attended the 2023 UC and spoke with a find ESRI gentleman regarding this topic. He told me to post here, so here I am.
Having the ability to adjust the symbol while editing would be greatly appreciated and edits would be easier to distinguish.
JMutunga
JenniferCadkin
This is implemented in ArcGIS Pro 3.4. Check out this Blog for more information about additional topological editing enhancements at ArcGIS Pro 3.4.
Go to Your Ideas in ArcGIS Pro 3.4 to see other ideas implemented this release and check out the What's New help to learn about everything that is new and improved in ArcGIS Pro 3.4.
